Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 05-26-2004, 07:34 PM   #1
Send a message via MSN to bgates1654
Drag Strip Results 5/25
I got in 5 frustrating runs total before I called it quits at 9:30.
Best Reaction Time: +0.085s (best 60' run)
Best 60': 2.313s (missed the 2nd shift and ended up with a 15.380@92.02)
Highest Trap Speed: 95.52mph (15.029ET 2.591 60')
Lowest ET: 14.743s (@95.00 w 2.350 60')
Thoughts: Disappointing... I was looking for 14.5-14.6 but I performed horribly. I missed second twice (not enough force to enter 2nd.. it seems like its getting harder to shift to second) and either had excessive wheelspin or bogged on launch. I red lighted twice.
I think the traction issue came down to the fact that my front tires were at 36psi. I think I could have improved 60' significantly if I took them down to 25-28psi. Plus only on the last run did I spin the tires to clean them up. I should get lower times and higher traps if I actually race prepped my car. I went with all my normal junk in it... just went in and pulled into the lane. I could take out all my junk, floor mats, spare, jack, and other minor stuff and see some improvement. The 3 runs that I did not screw up the shift I trapped 95+ which should be good for a 14.6 with a 2.3. I think I need to get out on an open road and just figure out the sweet spot for the launch. Once I get all that down I should be hitting 14.5.
I will post the entire info on the slips tomorrow tomorrow.
bgates1654 is offline   Reply With Quote
Old 05-26-2004, 08:34 PM   #2
Old Maxima Legend
Ceasars Chariot's Avatar
Send a message via AIM to Ceasars Chariot Send a message via MSN to Ceasars Chariot Send a message via Yahoo to Ceasars Chariot
i think you have a 14.5 , sometimes things just dont go your way, i know i can vouch for that the last few times out, lol ! good job !
__________________
N/A - 97 SE - VQ30DE - 93 octane
13.8 @ 98x - 2.06 60' - USIM
13.5 @ 101 - 2.10 60' - OOVI/EU
N/A - 97 SE - VQ30DE-K Swap
TBA
Ceasars Chariot is offline   Reply With Quote
Old 05-27-2004, 03:16 PM   #3
Okay here is the info from my slips in all their glory:
Run1
Reaction: +0.187
60': 2.591
330': 6.641
1/8ET: 9.920
1/8mph: 75.03
1000': 12.663
1/4ET: 15.029
1/4MPH: 95.52
Excessive wheelspin (note high 60')
Run2
Reaction: +0.108
60': 2.373
330': 6.828
1/8ET: 10.332
1/8mph: 70.87
1000': 13.191
1/4ET: 15.616
1/4MPH: 92.02
Missed second (note high 1/8 time)
Run3
Reaction: -0.146
60': 2.350
330': 6.383
1/8ET: 9.6554
1/8mph: 74.74
1000': 12.386
1/4ET: 14.763
1/4MPH: 95.00
One hell of a redlight and either wheelspin or bog (cant remember)
Run4
Reaction: +0.085
60': 2.313
330': 6.627
1/8ET: 10.087
1/8mph: 70.87
1000': 12.953
1/4ET: 15.380
1/4MPH: 93.55
Bogged a bit but my best 60' of the night. Felt like it was gonna be a good run until I missed second again.
Run5
Reaction: -0.085
60': 2.390
330': 6.488
1/8ET: 9.782
1/8mph: 74.47
1000': 12.554
1/4ET: 14.932
1/4MPH: 95.13
Bogged real bad on this one. The run felt pretty solid after the bog but obviously the bog was significant enough to give me a crappy time anyway.
Old 05-27-2004, 05:51 PM   #4
Send a message via AIM to bigdo26
list the mods too, all I remember you having is the TS ECU. I'm surprised your not trappping higher with the 6 speed actually... I was gettin in the mid 95's in my auto. Give it another shot sometime soon tho, you'll improve. You definatly have a 14.4 in ya
bigdo26 is offline   Reply With Quote
Old 05-27-2004, 07:53 PM   #5
Ah well in the way of mods I have:
OBX Catback
TS ECU
K&N GAB
All adds up to 223.0whp/237.2wtq SAE. The only thing I can say about not trapping any higher is that the temp was rather high about 78F and the huumidity was up there becuase it was supposed to rain all day and only did so for a breif but hard downpour in the morning. It also was sandwiched between big thunderstorms. It is also at 700ft above sea level. I could also suck at shifting.
Old 05-28-2004, 10:46 AM   #6
Ya the hotter temps dont help, neither does humidity. With those dyno numbers you should definatly be good for 14.5's at least. Dont wanna turn into a dyno queen just kiddin. Nah, get to the track again, you proved the Max can do decent with the 14.7 you posted, with better launch, shifting (maybe) and weather that'lll drop down. Dont fret about numbers anyways, just get out to have a good time.
Old 05-28-2004, 09:44 PM   #7
makes my timeslips feel slow from last fall. do you guys think going to the track once or twice a year will have a real impact on the auto tranny life?
slickrick is offline   Reply With Quote
Old 05-29-2004, 08:58 PM   #8
Update...
I just got a chance to scan soem of my timeslips. These are my best 1/4MPH and 1/4ET at dragway 42 on the 25th and my best 1/8MPH, 1/8ET, and best 60' at Magnolia Raceway on the 29th.
At Magnolia I took out all the trunk stuff (anything easily removeable except jack which I forgot about... whoops. Oh and found about a gallon of water that my spare was sitting in), floor mats, and aired the front tires down to 27psi (they felt like mush). Conditions were 58F, 75% humidity, and 29.84 on the barometer. The track is also at 900ft above sea level. Pulled my best 60' and got almost 2mph more on my 1/8MPH than at 42. Based on my numbers and the numbers I see here I should have run a mid/high 14.4 to a low 14.5 @ 97 or 98 in the quarter. I am satisfied with my runs there.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
