Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 04-25-2004, 11:50 AM   #1
RaWr!!! ('''_(o_O)_''')
Vlasic's Avatar
Send a message via ICQ to Vlasic Send a message via AIM to Vlasic
very disapointed with 1/4 time, what could be wrong?
that last time i went to the track, i was very disapointed with my times, and im wondering what could be wrong cus my times are horrible.
here are my times: (this was the best i could do)
Temp: 59 degreese
R/T: .516
60ft: 2.477
1/4: 15.37
this was with less than a 1/4 tank of gass and with the spare tire and jack removed.
i am on stick with intake and a cat-back. i see ppl post saying that they run 15.2 on a stock manual. the car has 107,000 miles on it. i bought it 16k miles ago and have done regular oil changes. i dont have the greatest clutch in the world, but its not so bad that it should effect my times like this. what could be effecting my times like this?
Vlasic is offline   Reply With Quote
Old 04-25-2004, 12:15 PM   #2
Old Maxima Legend
Ceasars Chariot's Avatar
Send a message via AIM to Ceasars Chariot Send a message via MSN to Ceasars Chariot Send a message via Yahoo to Ceasars Chariot
1. 60 foot needs work, a 2.2 would get you in the 15.1 area.
2. knock sensor - check for code
3. elevation
4. weather sometimes
5. tune up - check your plugs
about all i can think of
__________________
N/A - 97 SE - VQ30DE - 93 octane
13.8 @ 98x - 2.06 60' - USIM
13.5 @ 101 - 2.10 60' - OOVI/EU
N/A - 97 SE - VQ30DE-K Swap
TBA
Ceasars Chariot is offline   Reply With Quote
Old 04-25-2004, 12:25 PM   #3
Vlasic's Avatar
3. elevation
does the how to section have somehting on how to check the knock sensor? i have no idea how to do that.
the elevation wasnt too high, and it was rpetty cold that night. im planing on taking hte car in for a extended tuneup next week.
what spark plugs do you suggest i put in?
Old 04-25-2004, 02:18 PM   #4
Send a message via ICQ to speedemn Send a message via AIM to speedemn Send a message via MSN to speedemn Send a message via Yahoo to speedemn
Yeah you can check for the knock sensor code by using the directions in the how to, for how to pull ecu codes. If you get an 04 03 code then your KS is bad.
As Caesar said, a better 60' will get you the 1/4 ET that you are looking for. However, what was your 1/4 mile trap speed?
__________________
2003 BMW 540i 6-spd - present
2008 Toyota Rav4 Limited V6 - present
2005 Mazda 3 Sport GT 5-spd - past
1995 Maxima SE 5-spd black on black on black - past
Pacesetter STS | Stillen FSTB & RSB | Budget Y-pipe & B-pipe | PR CAI | MEVI | ACT Stage 1 clutch | UR flywheel | DM crank pulley | SSR Type C | JWT ECU | K-sport coilovers
13.89 @ 98.35
speedemn is offline   Reply With Quote
Old 04-25-2004, 02:40 PM   #5
Vlasic's Avatar
i got 15.37s @ 90.39mph
Old 04-25-2004, 03:08 PM   #6
Vlasic's Avatar
well i checked the ecu for any codes and none came up. the screw that im suppose to turn is the silver flat head one right? i turned it all the way to the right and waited 2 seconds, then all the way to the left and nothing came up.
Old 04-25-2004, 04:13 PM   #7
What was your highest trap speed of the day? The other guys here can correct me if I'm wrong, but a trap speed of 90mph is accurate for a 15.3 - sounds like a tune-up might be in order for you, as Ceasar suggested earlier.
Checking compression wouldn't hurt either, when you change your plugs.
__________________
13.89 @ 98.35
Old 04-25-2004, 04:15 PM   #8
Vlasic's Avatar
15.37s @ 90.30mph was my best time and speed of the day.
Old 04-25-2004, 07:16 PM   #9
I'm nutty for Nissans
JSutter's Avatar
Send a message via AIM to JSutter
Are you shifting into 4th? Check this out, if I keep it in 3rd my run looks like this:
R/T .658
60' 2.286
330 6.430
1/8 9.878@70.95
1000 12.851
1/4 15.358@89.35
But if I shift into 4th I get this:
R/T .561
60' 2.453
330 6.558
1/8 9.932@72.60
1000 12.832
1/4 15.282@91.54
Look at my trap speed, it went up 2.19 mph just b/c i shifted into 4th. My power mods are Stillen (hybrid) intake and a straight through muffler. So I say try shifting into 4th.
__________________
-Jon
Daily driver: 98 Maxima SE ... Best E/T: 14.9, Best trap: 95
06 Drag car: 91 Sentra SE-R ... Best E/T: 13.1, Best trap: 110, 2.2 60' R.I.P.
09? Drag car: 94 Sentra E ... In the making
JSutter is offline   Reply With Quote
Old 04-25-2004, 07:39 PM   #10
Vlasic's Avatar
ive tried staying in 3rd and shifting to 4th, but no matter what i cant get under 15.3
Old 04-25-2004, 08:22 PM   #11
I30tMikeD's Avatar
Send a message via AIM to I30tMikeD Send a message via Yahoo to I30tMikeD
I don't think the times are off by much. Low 15's in a 5spd max with basically no real power mods is normal to me.
I30tMikeD is online now   Reply With Quote
Old 05-01-2004, 06:58 AM   #12
Don't be discouraged - I remember when Ceasar was running 15.2's and it just seemed like we would NEVER break into the 14's, it just didn't seem like there was anything else we could do..... well, finally that bright red scoreboard threw up a 14.9 - I was so happy!
Like everybody else said, work on your launch, your 60's and Reaction are key to getting a good time. Experiment with the RPMs that you launch at... literally test them at in 200 RPM increments until you find the absolute max. RPM's you can launch at without spinning your tires.
Cut a good light, pray everything else goes great down the track, and bing, you'll be throwing up a 15.0 in no time.
Best advice, don't get fussed about a bad time, everyone expects to be a drag racing King when they go to the track, because, heck, it's just driving down a straight line as fast as you can, but as you get into it more and more, you'll realize that drag racing is a heck of a lot more than just going fast down a straight road...... it's actually kinda technical.
Have fun !!
Nismo_K
Ceasars wife and camera gal..
Nismo_K is offline   Reply With Quote
Old 05-01-2004, 11:15 AM   #13
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
Quote:
Originally Posted by Maxima10to1
R/T .658
60' 2.286
330 6.430
1/8 9.878@70.95
1000 12.851
1/4 15.358@89.35
R/T .561
60' 2.453
330 6.558
1/8 9.932@72.60
1000 12.832
1/4 15.282@91.54
No you didn't gain that speed from shifting into 4th. Analyzing the rest of your slip, you had gained that speed long before you ever were shifting into 4th. Look at your 1/8 mile speed, you were already going 1.65mph faster when you accelerating through the bottom of 3rd gear. Something else gave you that speed, but it wasn't the fact that you shifted into 4th.
Nealoc187 is online now   Reply With Quote
Old 05-01-2004, 11:16 AM   #14
SLOW
Nealoc187's Avatar
To the original guy, if you ran a decent 2.20 60' time you would be in the 14s, or REALLY REALLY close to it.
Old 05-01-2004, 09:46 PM   #15
Vlasic's Avatar
thanks for the responses. basically the way to achieve a better 60' time is to work on my R/T and launches?
Old 05-02-2004, 06:20 AM   #16
I30tMikeD's Avatar
RT has nothing to do with your time if your running Test and Tune. The launch is what it's all about.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
