Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 04-25-2004, 10:41 AM   #1
Old Maxima Legend
Ceasars Chariot's Avatar
Send a message via AIM to Ceasars Chariot Send a message via MSN to Ceasars Chariot Send a message via Yahoo to Ceasars Chariot
Drag Strip Guru's - need a crash course on weather and racing
TIMESLIP WEATHER REPORT - Posted below are my best times at the local tracks around here. I dont understand the weather and the relationship with helping or hurting performance. If its cold outside, and the humidity is low. I usually say, hey its a good day to race !
Does the pressure have a big impact also ? Wanted someone to look over this in relation to my best times and explain (if possible)
no problem**** state capitol*** hub city****finishline
Time
14.16 ----------- 14.25 -------- 14.29 -------14.14
Temp
60----------------53-------------69------------51
pressure:
30.3--------------30.2-----------30.9----------29.9
humid:
48%--------------86%-----------24%----------76%
wind:
6 mph E----------10mph E--------calm---------10mph ENE
__________________
N/A - 97 SE - VQ30DE - 93 octane
13.8 @ 98x - 2.06 60' - USIM
13.5 @ 101 - 2.10 60' - OOVI/EU
N/A - 97 SE - VQ30DE-K Swap
TBA
Ceasars Chariot is offline   Reply With Quote
Old 04-25-2004, 02:28 PM   #2
Send a message via ICQ to speedemn Send a message via AIM to speedemn Send a message via MSN to speedemn Send a message via Yahoo to speedemn
In my opinion, the factors listed in terms of importance are: temperature, humidity, baro. pressure. All 3 together are variable enough to affect your times, assuming that all other conditions are constant (ie, your driving style and track conditions).
All that being said, I think that the track condition of the different tracks would be the largest factor in your times in this case... they are all quite close to each other in terms of weather conditions. Are the tracks all that different?
I've had the opportunity here to compare quite contrasting temperatures (I have never looked at baro. pressure when I go racing though) and that is what I have found.
It would be interesting to see what some of the other guys think.
__________________
2003 BMW 540i 6-spd - present
2008 Toyota Rav4 Limited V6 - present
2005 Mazda 3 Sport GT 5-spd - past
1995 Maxima SE 5-spd black on black on black - past
Pacesetter STS | Stillen FSTB & RSB | Budget Y-pipe & B-pipe | PR CAI | MEVI | ACT Stage 1 clutch | UR flywheel | DM crank pulley | SSR Type C | JWT ECU | K-sport coilovers
13.89 @ 98.35
speedemn is offline   Reply With Quote
Old 04-25-2004, 03:42 PM   #3
Old Maxima Legend
all 2.1 60 foots on these runs
Old 04-25-2004, 04:11 PM   #4
Quote:
That does not necessarily mean that the tracks are equal. Last year I would have thought the same as you, but this year I found out (even after consulting with other people) the following:
St. Thomas, Ontario:
Track yields horrible 60' times but trap speeds are higher
Cayuga, Ontario:
A "bad" 60' time here = the best 60' time at St. Thomas, however trap speeds are always 1-2mph slower at this track, if not more. My buddy gets about 4mph slower traps in his Mustang between the two tracks (better 60' here, and similar ETs).
This is all, weather conditions approximately equal. Elevation is about the same +/- 100m... or less.
Grrr all this track variation sucks and with our weather it is hard to maintain the tracks... I wish I could come race at your no problem track... where is it exactly???
__________________
13.89 @ 98.35
Old 04-25-2004, 05:25 PM   #5
Old Maxima Legend
Its in the Baton Rouge, LA -- New Orleans, La area.
Old 04-25-2004, 05:49 PM   #6
Thinks he owns a sports car
Assume windage and trackprep are identical. Then remove launch differences for the different temps (sunny, overcast, etc.). That leaves only power differences right?
Correction factor for power looks something like this.
CF = 1.18 * (29.22/Bdo) * ((To+460/537)^.5) - .18
Bdo = absolute pressure (not relative)
absolute pressure = realtive hum - (elevation / 1000)
To = outside air temp
Using corrected power your last run is .44sec faster than run #3 if I got it right. I agree temp is always the most important but maybe that ENE wind had something to do with it. Does the track run southward?
BEJAY1 is online now   Reply With Quote
Old 04-25-2004, 06:12 PM   #7
96sleeper's Avatar
Send a message via AIM to 96sleeper
these guys are all right. The best racing conditions are:
sun shining on the track which warms the surface and helps traction.
cold temperature.
low humidity.
high pressure.
The best temps seem (for me at least) to be in the low 40's. Any colder than that and traction suffers terribly. I have run in 20 degree weather and although I trapped well, I never ran a new best E.T. Humidity is the second most important. Pressure does make a difference, but it is the least important of the factors. I have around 300 timeslips and I have been tracking weather conditions, these do seem to correlate pretty well.
__________________
96 Pebble Beige SE
14.2@97mph as an auto
13.7@102mph as a 5spd
12.9@106mph after 3.5 swap
11.6@120mph with the S/C
Visit here for mods and dyno.
2005 Nismo Frontier 4x4
96sleeper is online now   Reply With Quote
Old 04-25-2004, 07:51 PM   #8
Old Maxima Legend
Elevation
No Problem Raceway - 23
Hub City Dragway - 161
State Capitol - 53
Finishline - 487
im messing around with this calculator thing at http://wahiduddin.net/calc/calc_hp_dp.htm
cant make much sense out of it, is there something better to use ?
It appears to me Hub City and then No Problem were the best days to race, but then again im not sure about any of this. Also after looking at some of this stuff and my timeslip from finishline dragway im not sure my times are accurate at all.
Old 04-28-2004, 12:18 AM   #9
Evo Driver
Send a message via Yahoo to SmoothMax
Ceasar,
Is your 2.1 60ft on street tires or radials? I apologize in advance for going OT.
__________________
SmoothMax is offline   Reply With Quote
Old 04-28-2004, 06:39 AM   #10
Send a message via AIM to SonicDust187
ceasar is on street tires.
SonicDust187 is offline   Reply With Quote
Old 04-28-2004, 07:03 AM   #11
Old Maxima Legend
hey no problem about OT, i found out much of what i needed to learn. pretty cool ! toyo proxes t1-s is what im using
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
