Quote:
Originally Posted by Max_PR
1. It's can't be that I need pratcice driving because as I said before I did 2.4's when it was stock on every run. Now launching the car in the same manner as I did that OTHER night in which I always pulled 2.4's it throws 2.5's.
2. Isn't the MEVI supposed to imrove my 1/4 mile time?
No, you do need practice launching because an auto max with a driver who knows what they are doing should be able to get 2.2x 60' or even 2.1x. This is regardless of mods.Your idea that your seeing horrible 60' foot times because your mods added power is incorrect. It's because your not good at launching your car. It's nothing personal, it just takes practice.
you can't duplicate lauches perfectly, especially on different days. There is just too many different factors that you can't control. ie; track prep, temperature...
An MEVI (with out an extended redline) is not ment to see gains in the 1/4 mile. The benefits come at highway speeds, 60+mph. The MEVI will cause a loss of around 10lbs, maybe even 15lbs of mid-range torque. Low/mid-range torque is essential for a low ET. So even though an MEVI can gain 20hp+ above 6K rpms the loss of mid-range torque negates the gains...as far as running the 1/4 mile is concerned. A max with an MEVI will enjoy the gains in racing from roll not a stand still.
So, go practice your launch and if your only concern as far as speed is to run low 1/4 mile times then don't get an MEVI (unless you plan on gettting the redline extended). If you enjoy highway power and a more refined power band then get the MEVI.
