Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 11-29-2003, 04:36 PM   #1
Send a message via AIM to NJ02maximaGLE
how to rev engine safely before race
how can I get my rev's up at the line with an auto transmission (maxima GLE) without dropping my transsmission?
NJ02maximaGLE is offline   Reply With Quote
Old 11-29-2003, 10:04 PM   #2
Old Maxima Legend
Ceasars Chariot's Avatar
Send a message via AIM to Ceasars Chariot Send a message via MSN to Ceasars Chariot Send a message via Yahoo to Ceasars Chariot
interesting technique: i was just reading about.
I don't brake torque at the line which is what most people will tell you what to do. I do a small burnout to clean off the tires. I stage and then on the 3rd yellow, I give it gas for a split second as I am still on the brake. It is almost like both feet are moving at the same time. gas pedal going down, brake pedal moving up. It is hard to explain, but it is called "flashing" the torque converter. Instead of brake torqueing you are trying to get the converter to catch right as the car is starting to move. When you "shock" the torque converter like this it lets you leave the line at a higher rpm faster. Hope this helps, it is hard to explain
source: http://forums.maxima.org/showthread.php?t=266912
Ceasars Chariot is offline   Reply With Quote
Old 12-02-2003, 10:50 AM   #3
brake torque? i'm new to these automatic terms, always had 5-speeds. i'm guessing that's when you rev it in neutral and drop the proverbial hammer? any help would be appreciated as i'm new to automatics. thx
apbrian112 is offline   Reply With Quote
Old 12-02-2003, 03:52 PM   #4
NWP Engineering.com
Aaron92SE's Avatar
Send a message via AIM to Aaron92SE Send a message via MSN to Aaron92SE Send a message via Yahoo to Aaron92SE
Quote:
OH NO! That is what we refer to as a "Neutral Drop". haha... you'll hear a clunk, your tires will spin and more than likely, you'll run over your transmission that just fell on the ground.
A brake torque is simply when you hold the brakes firmly and give the car some gas to raise the engine speed. Don't hold it for long periods of time b/c it builds up a lot of heat in the torque converter. And it's not good for the tranny.
What I do at the track is just what I explained above. Not the N drop, but the brake torque.
Aaron92SE is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
