Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 11-09-2003, 12:54 PM   #1
Send a message via AIM to sk24iam
overdrive?
Best to keep it on or off?
__________________
-Stephen
97 Black on Black modded GLE
NYC MAXIMAS
sk24iam is offline   Reply With Quote
Old 11-09-2003, 05:04 PM   #2
Send a message via AIM to Turismo
Most choose to keep it on, or not have the OD=OFF light on. The reason being is in a 1/4 mile, there's just enough room for the overdrive gear to give it a little extra juice. If you're not racing a full 1/4 mile, then you'll probably want to turn it off--this way you car stays accelerating in 3rd gear, giving the most horsepower to your wheels in that shorter amount of time--OD would probably hurt your total time.
__________________
SHIFT_"Count my doors, b!tch!"
Turismo is offline   Reply With Quote
Old 11-18-2003, 09:14 AM   #3
ABK
Send a message via AIM to ABK
So how exactly does it affect the third gear, and y do my rpms jump when I drive in second and turn off the overdrive?
ABK is offline   Reply With Quote
Old 11-18-2003, 11:24 AM   #4
Send a message via AIM to bigdo26
under WOT, the car locks the torque converter and since overdrive is not actually another gear (read up on it on howthingswork.com) the car wont shift into "4th" during a 1/4, or probly even a 1 mile race for that matter. If you run the quarter mile and try turning OD on then off and back and forth as you're drivin, there will be no difference in the times, since the overdrive does not change gearing, increase power, etc. sorry guys
bigdo26 is offline   Reply With Quote
Old 11-18-2003, 12:07 PM   #5
Quote:
that clears that misconception up. so od off = stretch out third gear, avoids going into a cruise gear - 4th in Autos.
__________________
Ferbs
Sterling Mist
02 Nissan Maxima Auto
Best et and trap 14.60 @ 95.80 2.27 60'
Best 60' 2.195 - Sumitomo HTR+
Berk Intake/Cattman Ypipe.
Need: 2.1xx 60' time. She has 14.50's in her...
http://www.cardomain.com/memberpage/445230
Ferbs02SMMax is offline   Reply With Quote
Old 11-18-2003, 01:38 PM   #6
Jime's Avatar
Actually the car will shift into 4th in the 1/4, mine does it all the time. It does change the gearing. All you have to do is hit redline in 3rd while O/D is on and it shifts. Mind you, your car has to be fairly fast for this to happen. My speedo is hitting around 125 MPH when it shifts even though I am just over 100 MPH because of the size of my front tires. (22")
If I didn't shift into 4th or O/D my engine would be bouncing off the rev limiter before the end of the 1/4.
__________________
0-60 MPH = 2.38 sec
Jime is offline   Reply With Quote
Old 11-18-2003, 05:15 PM   #7
Jime - you might be the exception I only trap around 95, and since I dont have smaller wheels for the strip, my speedo only reads 95, so i'm right in the middle of 3rd. So leaving OD on wouldnt make a difference. But I trust the opinion of you more than myself, a college kid. By leaving OD off, you're saying the gearing for 3rd is different than when OD is on? I've never noticed any difference in RPMs when i'm in 3rd vs Drive...
Old 11-18-2003, 06:02 PM   #8
Jime's Avatar
You are correct is saying that there will be no difference in times with O/D on or off. 3rd is is 3rd gear, the ratio is the same no matter what we do.
But the car will shift into 4th in the 1/4 you just have to be going fast enough and 4th is actually another gear. When I said it changes the gearing, I mean when it shifts from 3rd to 4th. Not sure what you mean by saying that 4th is not actually another gear.
Old 11-18-2003, 07:07 PM   #9
Hmm... its been a while since i've looked at how the auto tranny really works. I must have misunderstood the articles I read a few years ago... overdrive is another gear like you said. sorry for the mis-information. I think I misunderstood my readings in that the overdrive causes faster output speed than input speed, the opposite of a gear reduction which 1st-3rd do, at least for our trannys. Somehow I misread that as overdrive being like a variation of 3rd gear??? Not sure. Anyways, yes, 4th is another gear, as you said. Ha I doubt my car will ever be fast enoguh to shift into 4th gear/overdrive in the 1/4! But thats ok...
Old 11-21-2003, 11:51 AM   #10
Just to help ... Torque convertor lock up and overdrive are two different things. "Lock up" is when the torque convertor is mechanically "locked" and allows no slipage/torque multiplication. This is more effecient when cruising on the highway because the torque convertor is not slipping/stalling and transferring all power to the wheels and also lowers cruising rpm's. Lock up can be helpful at the top end of the 1/4 mile also, if the trans. can handle it. Overdrive is actually a gear... and in our case (auto's) 4th. In a 5 speed Maxima it would be 5th. I know on a 6 speed Vette/Camaro/Firebird, 5th and 6th are both overdrives.
Just sharing good news,
Gears
Gears & Crosses is offline   Reply With Quote
Old 11-21-2003, 01:06 PM   #11
Blu
the tits
Blu's Avatar
Send a message via AIM to Blu Send a message via Yahoo to Blu
Hopefully I will be into 4th tonight at the strip
Blu is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
