Time to be Captian obvious here, your first run was in September and then your best run was in January. I'm sure your driving definately improved, but it at all can be attributed to your skills, especially seeing that you're an auto. Your 60' improved, but the fact that your trap speeds went up says the conditions were the main factor in the improvement.
Using wunderground.com, the conditions for Montgomery, AL on 9/7/01 were upper 80s with humidity in the 50-70% range. Conditions on 1/31/03 were mid 50s with humidity in the 60-70% range. With as much racing as I've done, I know that a difference of nearly 35 degrees in temp makes a HUGE difference in the way my car performs. On a hot day with high humidity, my car is ~.3-.4 and 3-4mph slower than running on a cool crisp day.
Dave
__________________
2003 Black G35 sedan automatic
Best ET: 14.32, Best MPH: 99.87mph
Mods: MD spacer, HR y-pipe, RevUp airbox, Z-tube, 05 sedan midpipe, 350Z/Coupe springs, lots of other stuff
Sold -1996 Black SE 5-speed MEVI & JWT ECU equipped
14.31@99.34mph with a 2.18 60'
