Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 04-16-2003, 08:26 PM   #1
Send a message via AIM to Requin6
can i reasonably expect a 13 second pass?
well as some of you may know, i am looking to run a 13 second pass without the use of boost or juice. i am close at 14.302. my setup on that day was...
full interior...removed spare and jack
street tires
intake, Y, UDP, ECU, MEVI
65 degree day, very sunny...track temps could have been in the 80's
i have recently mounted a set of BFG drag radials on my 15in. sawblades. anyone have any feedback on drag radials vs. full on slicks? i want to be able to drive my car to the track without having to swap out tires, thus making my choice on drag radials an easy one. my question is...knowing that i have run 14.3 in full trim, should i have expectations of running a high 13 with new setup of a)drag radials and b)removed front and rear seats
can i shave 3-4 tenths by getting the sticky tires to hook up with a hotter launch and reduced weight?
http://images.cardomain.com/member_i...8_102_full.jpg (darn 50k limit)
i am going down to MIR (Maryland Int'l Raceway) on the 25th to see if i can conquer my demons. this is the same track i ran 14.3 at.
thanks for reading, and for your thoughts on the matter.
--Paul
__________________
1996 Deep Evergreen SE 5-Speed
12.9 @ 111 - Street Tires
Requin6 is offline   Reply With Quote
Old 04-16-2003, 09:05 PM   #2
Paul I think its very possible. If you can shave .2tenths off your 60ft, don't know what that is though? Make sure your dr's are really warmed up-follow man. suggestions. And stiffen up the rear to avoid weight transfer. FYI-I would take out the interior before you go. It might not make much difference in E.T. but at least you don't have to keep up with the ish at the track. Good luck
tampamax is offline   Reply With Quote
Old 04-16-2003, 09:18 PM   #3
Quote:
yeah i am going to leave the interior at home. sorry i didnt post my 60ft....i have before...i run consitant 2.2 60fts.
last time out the track i went to was an absolute mess, my best 60 was high 2.3 and i still ran 14.4. @ 99.
--Paul
__________________
Old 04-17-2003, 08:24 AM   #4
--Paul
your trap speeds are phenominal! you should be able to run 13's. i ran at atco this past tues night and i was getting 14.3s. my launches weren't that great this time due to a very sticky track. i bogged every launch with 2.2 60's. hopefully next time the track won't be so crowded and i'll have more passes.
VQdriver is offline   Reply With Quote
Old 04-17-2003, 07:10 PM   #5
Send a message via ICQ to Nismo87SE Send a message via AIM to Nismo87SE
Re: can i reasonably expect a 13 second pass?
Drag radials probably won't cut it, while they are better than street tires they suck compared to slicks. Cartest shows that your car should run 14.2s @ 97-99mph with a 2.2x 60' assuming race weight is ~3200lbs. With a 1.9x 60' cartest shows a 13.8s @ 99-100mph given the same weight. If your going for 13s get the lightest rims you can and throw some slicks on!
--Paul
__________________
87 Nissan maxima SE auto: RIP
91 SE-R:
Best ET: 14.57 at 90.4 with 1.90 60ft.
Quote:
BMW gets girls. MB gets women. Maxima gets dirty - Daniel B. Martin
Nismo87SE is offline   Reply With Quote
Old 04-17-2003, 09:03 PM   #6
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
I don't think DRs alone will shave off the .3-.4 you are looking for. I bet more like .15-.25 seconds. I only run .35s faster on full slicks than on street tires.
What are your traps usually. 97-99 is a big range. If you are above 99 consistently I can see it happening with your current setup and the weight reduction.
From taking NOTHING out of the car to take all the things out like seats, spare, jack, I only drop .1 second, and I gained about .5mph.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 04-17-2003, 11:35 PM   #7
Jime's Avatar
Drag Formula
100 lbs = 10 HP = .1 in the 1/4
__________________
0-60 MPH = 2.38 sec
Jime is offline   Reply With Quote
Old 04-18-2003, 02:41 PM   #8
guy from waterboy said it best...."YOU CAN DOOOOO IT!!!!!!!!"
__________________
1998 SE 5 speed
14.59@94.84mph
luckee2bhere is offline   Reply With Quote
Old 04-21-2003, 07:41 AM   #9
ejj
Send a message via AIM to ejj
Quote:
Not even. I used 'em last year and didn't see an improvement in times at all. They were fun to beat on though.
ejj is offline   Reply With Quote
Old 04-22-2003, 05:50 PM   #10
seat removal and DRs wont do it...driving skillz will
__________________
1998 SE 5 speed
14.59@94.84mph
Old 04-22-2003, 10:39 PM   #11
Not DAVEB the parts guy
All I can say is good luck. Air down the drag radials to about 18psi when you get to the track, get the tires a slightly wet, get about 5' out of the water box, do a 10 second burnout, and then roll to the line. The 10-second burnout and rolling to the line is what BFG recommends. Don't do any "dry hopping" after the burnout.
Why the 235/60s on the 15s? Aren't those a bit taller and heavier than the 215/60s?
With better hooking tires, reduced weight, sticky track, and a cold night, you possibly could eek out a 13.999. Your MPH is there, it's you initial 100' of acceleration that's killing you. I know how you feel though (look at the sig)
I'll just be very happy with a 14.2@99mph at 1100'. I'm going to the track tommorrow night, weather permitting. I've gone ahead and threw on my HKS hybird intake since I've never tested it with the MEVI/JWT. If the weather holds, the temp (lower 50s), low humidity, and baro pressure could be ideal. The track has been hooking hard lately. Fingers are crossed.
Dave
__________________
2003 Black G35 sedan automatic
Best ET: 14.32, Best MPH: 99.87mph
Mods: MD spacer, HR y-pipe, RevUp airbox, Z-tube, 05 sedan midpipe, 350Z/Coupe springs, lots of other stuff
Sold -1996 Black SE 5-speed MEVI & JWT ECU equipped
14.31@99.34mph with a 2.18 60'
Dave B is offline   Reply With Quote
Old 04-22-2003, 11:10 PM   #12
Quote:
Dave
GOOD LUCK BUDDY!!! Let us know how it turns out...
__________________
1998 SE 5 speed
14.59@94.84mph
Old 04-23-2003, 04:51 PM   #13
Dave
235/60 and 225/50 are the only sizes remotely close to the stock size on 15's i had 225/50's on backorder for the longest time and they told me they arent expecting them anytime soon so i went ahead and got the 235/60's. thanks for the good luck wishes...looks like i will be crossing my fingers for no rain before i can cross them for 13's. i just hope to get some clean runs in and see what happens.
btw--good luck at the track.
--Paul
__________________
Old 04-23-2003, 07:27 PM   #14
--Paul
Heavy rain right now. No racing until I get back from Hawaii
Dave
__________________
Old 04-24-2003, 02:43 AM   #15
NWP Engineering.com
Aaron92SE's Avatar
Send a message via AIM to Aaron92SE Send a message via MSN to Aaron92SE Send a message via Yahoo to Aaron92SE
Remove the AC belt. If you want, find a way to get colder air to the intake. Maybe reroute your intake to a removed headlight. Much like this: http://www.javay.com/bbs/CAIramair.jpg
Make your front tire pressure to 18 psi and rear to about 45psi. Remove all seats and gut your trunk. I would say to advance your timing, but that's a VE thing.
Aaron92SE is offline   Reply With Quote
Old 04-25-2003, 06:07 AM   #16
i hit up atco raceway this past thursday afternoon and it wasn't very crowded at all. i was able to run 8 times. my best time for the evening was 14.05 (see timeslip forum). that's a new PR for me. i smoked the tires on two runs (14.8, 15.1). i had three 14.1's, a 14.2, 14.3 and a 14.4 with a lot of wheelspin against a newer mustang gt conv. i still won that race of course. you guys with the MEVI and JWT ECU have phenominal trap speeds. my car is lacking in power. i'm not sure if my car can break the 13 second barrier without adding more mods. maybe i'll just take out a chunk of metal next time lol. this might be it for a while...
Old 04-25-2003, 09:21 AM   #17
Quote:
awesome time on the 14.05...doesnt look like i will be able to get to the track tonight...heavy rain is moving in i guess my day will come eventually.
--Paul
__________________
Old 04-25-2003, 11:44 AM   #18
RUDY IS DA MAN
__________________
1998 SE 5 speed
14.59@94.84mph
Old 04-25-2003, 11:23 PM   #19
Quote:
Originally posted by luckee2bhere
RUDY IS DA MAN
haha thanks adam.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
