1/4 and 1/8 Mile RacingTalk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
im going to the track on wednesday tentatively. i have a 2k2 se auto and was wondering what psi would be ideal for my tires for the best overall time? the weather will be in the 50's-60's. thanx.
Originally posted by slickrick im going to the track on wednesday tentatively. i have a 2k2 se auto and was wondering what psi would be ideal for my tires for the best overall time? the weather will be in the 50's-60's. thanx.
Try 25psi then if you are still having problems slowly dicrease it. It seems for me it all depends on the day and the track surface. Some times I don't change my pressure at all, and some days I have to run 25 or below???
I usually run my fronts about 25 also. If I still loose alot of traction I let it out to 20. Then, by the end of the night before I leave I check the tire pressure and it's usually close to 15. I pump my rears up to 45. 55 is kinda high for me.
if you put it too high would it just pop off the rim or would you need to buy a new tire?
You won't do it any damage. I had to pump my slicks up to over 100 psi to get them to seat and they only weigh 11 lbs and are super thin so I don't think you could possibly hurt a regular tire unless you ran for an extensive distance at like 100+.
Re: Re: Re: Re: Re: Re: Re: Re: what psi for tires?
Quote:
good to know...ill trust you...but guess who the first person to get an earfull will be if my tires blow?
are you not scared of the tire coming off the rim at 100mph???
Re: Re: Re: Re: Re: Re: Re: Re: Re: what psi for tires?
They won't come off the rim, if anything they will blow. I have already had that happen a couple of times a few years ago when I couldn't afford new tires.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: what psi for tires?
so now you are saying that they have blown on you before when you pumped them up too high??
and when they blow they dont come off the rim? i thought that would be a definite effect of a tire blowing at 100mph...
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: what psi for tires?
NO I am not saying they have blown on me when I pumped them too high.
I am saying I have had old tires blow at high speeds when I was a teenager because I couldn't afford new tires. The were at normal pressures.
