Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 03-28-2003, 05:52 PM   #1
"I'm running with scissors!"
mayhemI30's Avatar
stall converter question
im gettin a stall converter from level ten installed on April 7th.
just wondering if anybody has an aftermarket one. i need a little info so i know what to expect.
__________________
02' Altima 3.5SE 5spd
Frankencar intake w/Apexi filter
HS headers
Greddy SP2
8.913 @ 84mph 1/8 mi
2.12 60 ft
mayhemI30 is offline   Reply With Quote
Old 03-31-2003, 06:51 AM   #2
Expect a lot more acceleration! Assuming you have traction and your shift points don't raise and your engine hits the revlimiter before shift. I'm afraid you will need re-programming for a converter to work with our transmissions.
If you are looking for maximum acceleration you will need a 3900 rpm stall converter. Our engines make max torque at 4400. Maximum acceleration is attained around 500 rpm blow max torque. Of course the looser converter you get the higher the rpm will go under part throttle acceleration. A good street converter would be around a 3000 stall. Don't get too loose a converter or you will be sorry later on.
Traction will be a major concern. You will need some real sticky tires or even slicks to hold traction. Particularly with our front wheel drive.
Good luck and let us know how you come out.
Larry is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
