1/4 and 1/8 Mile RacingTalk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Are their any sites that can predict what rpm I will be at in 4th gear with a certain diameter tire, or what size tore I need to not have to shift out of third but still run 120mph?
Are their any forums for hard core FWD races to discuss suspension set ups?
__________________
Parted out and sold the fastest that was...
Now a G35 Sedan, Built Motor, Greddy TT... Trying to be as fast on street tires and the Max was on slicks
Originally posted by MardiGrasMax Are their any sites that can predict what rpm I will be at in 4th gear with a certain diameter tire, or what size tore I need to not have to shift out of third but still run 120mph?
Matt, you don't need any help.
Most of the hardcore guys I know are DSM and of course their suspension requirements are totally different from ours.
I was looking at my rear coils and I cant figure for the life of me how the heck you get those inserts in their and wraped around the strut shaft? I have Eibach springs maybe the coil spacing is tighter than what you have, what springs do you have?
I am considering somthing like welding a set of stock struts fully extended to jack the back up and get zero squat. But it will be a pain to swap out rear strut housings at the track.
Maybe air bags? Or do they make air struts for coil over set ups? I'm looking for a way to firm up the back and rais it up whick dosent involve too much work at the track?
__________________
Re: Re: Re: Some links needed for drag racing help
Help, well perhaps mental help
I had to cut off the dust covers, I have stock struts and Maxspeed Springs, its fun to get them in there and I now take the rear wheel off to do it vs jacking up and crawling under.
I am thinking about making a bracket for the top and bottom that extends out towards the center just past the spring and then just bolting a solid rod between them at the track. You are right though gotta be an easier way. I'll let you know if I come up with an easier method.
I tried chaining the front down too but didn't seem to help much like the rear did. Makes a rough ride on the return road though with the rear rigid.
Anyway I am still looking at an easier way, some morning I will wake up with a better idea, I hope.
Originally posted by MardiGrasMax Thanks Cincy, good stuff!
I like the zip ties, thats crazy, but prolly effective. and 3/4" spring spacers, thats got me written all over it!
No problem. Those ideas, combined with some others I have, should get my VG auto into the 16.1 range and possibly the 15's this summer without using any power upgrades. If the ideas can work with my anemic 120 or so HP, I'm sure they can work with your gobs of HP and help you reach your much more noble goal of 11's. If I find anymore info, I'll send it your way. Have a good day.
__________________
94 Maxima | 96 Integra GS-R | 94 Integra GS-R | 02 G20 Sport | 00 Maxima SE
And some nice tie wraps to hold my front from coming up. Dude, that is awesome. That has got to be the worst problem I have with my car. My front end rises SOOOO much on the launch. I am always looking for cheap mods. I thought I ran out of cheap mods, but I just found another. Muwahaha!
__________________ NWP Engineering Phenolic Thermal Intake Spacers 10hp and 12ft-lb gain & 40°F temp drop on the VQ35DE
You can enter in your tire size and gear ratios and it will give you MPH at every rpm through the band. Check out the rest of the auto math on the page too, you can enter in two different tire sizes and compare them.
__________________
96 Pebble Beige SE
14.2@97mph as an auto
13.7@102mph as a 5spd
12.9@106mph after 3.5 swap
11.6@120mph with the S/C Visit here for mods and dyno.
Anytime you need some mental stimulation, just go and read the DSM threads in the Advanced Discussion area over at www.dsmtalk.com . Those guys know their stuff and do some crazy stuff with it too. They've been going fast since 1990 and their knowledge base is huge.
__________________
Oh yeah, how exactly would you install these zip ties? Would you only wrap it around the two spring coils that are closest to each other? Or would you skip a row and wrap it around more than 2? I hope this makes sense.
Originally posted by Aaron92SE Oh yeah, how exactly would you install these zip ties? Would you only wrap it around the two spring coils that are closest to each other? Or would you skip a row and wrap it around more than 2? I hope this makes sense.
Thanks SR... now I just need to find if I have one in my area.. Las Vegas. I know we have an industrial supply store called Fasco. I'm sure they will have something.
