Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 09-05-2002, 10:13 AM   #1
All Black Max
Send a message via AIM to DougsfastZ
Damn, this close to 14's
I took my stock 96 SE 5 spd to the track again. Here are my first numbers:
Quick question RE Dashboards
The new numbers:
2.26 60' 15.01 @ 90.83
The only differece from before is I took out the spare, jack, jumper cables and ran only 2-3 gallons of fuel (right before the warning light came on). The car now only weighed 3000 lbs w/o me 3155 with me. I did also change my shift points to 6500 1-2 6200 2-3 and 6000 3-4. I want to thank Nealoc187 and Soon2BMaxed for informing me about the proper shift points.
The weather was slightly different. 81 degrees, 78% humidity, and the same baro 29.98.
I pretty much launched the same as before, approx 2700 with very little clutch slip.
I backed up the numbers with a 2.36 60' 15.06 @ 91.0 (that would have been my 14 sec run if I didn't try to launch so hard).
I did find something very interesting.
These cars are VERY receptive to the heat of the motor. I was running 15.8's with 2.4x shorts and scraching my head figuring out whats wrong. The motor was running normal temps, right in between H and C (man I wish Nissan would have given us numbers on the temp gauge)
I bought a bag of ice and placed it on the intake and let the car sit for an hour before I ran. The temp gauge showed about the 1/4 way up from C with a cool to the touch intake on both the 15.0x runs. I'm not sure what the actual temp is, but I can definitly see a difference in the numbers and a SOTP difference. It is also much harder to launch the car since there seems to be more wheel hop with the added power.
I'm still very happy with the numbers. I will be going next week with the same setup, but running a switch to manually turn the fans on shooting for 14's, stock
Doug D
__________________
1995 Juiced Camaro Z28 12.66 @ 119 SOLD
1996 Nissan Maxima SE 5 spd
CAI, ACT Clutch, Red/Clears, MEVI, full custom 2.5" exhaust, 2" drop with sprints/KYB AGX's, Borbet Type E's 17x8's
CAI only times: 2.29 60' 14.96 @ 91.78
DougsfastZ is offline   Reply With Quote
Old 09-05-2002, 01:15 PM   #2
Send a message via AIM to Anuj
Re: Damn, this close to 14's
The new numbers:
Doug D
good luck..and change your sig
__________________
2002 Nissan Maxima Sterling Mist
2000 Honda S2000 New Formula Red
Anuj is offline   Reply With Quote
Old 09-06-2002, 01:59 PM   #3
You said you put a bag of ice on the intake!? What exactly do you mean? I'm assuming that it's the intake box you put it on.
Dave.
Punch84 is offline   Reply With Quote
Old 09-06-2002, 03:59 PM   #4
Evo Driver
Send a message via Yahoo to SmoothMax
Hey, that's impressive! Looks like you'll be going down the same path I did. Most of the folks on the board who run low 14's w/ I/Y/E started off running high 14's stock.
__________________
SmoothMax is offline   Reply With Quote
Old 09-06-2002, 04:09 PM   #5
All Black Max
I simply put the bag of ice on top of the intake manifold in between rounds.
Doug D
__________________
Old 09-06-2002, 09:34 PM   #6
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
Nice job.... you are so close. Hit the track next week and you join the stock 14 second club I bet.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 09-06-2002, 09:51 PM   #7
Doug D
you're doing very good. i remember my very first run ever was 15.1@92mph. i was very happy just to do better than the motortrend time. with more practice you'll get into the mid/high 14's with just a cone filter. good luck.
VQdriver is offline   Reply With Quote
Old 09-09-2002, 01:23 PM   #8
Try holding third gear. I know we're losing power after 5600 rpm's but for some reason I get my best times red-lining each gear.
Also, you'll do better when the humidity drops.
Terry
__________________________________________________ ________________
98 SE/ 5 speed/ CAI/ UDP/ Stillen Y pipe/ RT cat/ Courtesy B pipe/ Stock muffler
FSTB/RSB/ Clear front bumper lenses/ Clear tails
178 fwhp/191 fwtq
14.73 @94.1
maxfreak_98 is offline   Reply With Quote
Old 09-09-2002, 09:42 PM   #9
SLOW
Nealoc187's Avatar
He tried holding 3rd before. I think this worked better for him.
__________________
3.5L - I/Y/E - USIM
Old 09-09-2002, 09:54 PM   #10
Use the Search Function!!
mtrai760's Avatar
Send a message via AIM to mtrai760
I tried running out 3rd gear and got a best time of 15.2, and I was running at almost 6500rpm when I crossed the line, a 4th gear shift would have helped me out I think...
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
mtrai760 is offline   Reply With Quote
Old 09-10-2002, 09:02 AM   #11
Dynaudio 362 Fan
meccanoble's Avatar
Send a message via AIM to meccanoble Send a message via MSN to meccanoble Send a message via Yahoo to meccanoble
all this shifting information is very helpful. Thanks guys, someone should post a thread of how to properly run when on the track. Gears to shift, what rpm to start on (in his case 2700)...dam 2700? my tires would spin like hell if i started taht high, maybe cause he got stock and i have a few mods....
__________________
SHIFT_early!!! Gas is too expensive
2k1 SM SE 5MT aka SMOKEY
RIP 97 RW SE 5MT SC
RIP 95 BE GLE 5MT
B&M STS|Top Element shift bushing|AE pedals|AVN5435 | Dynaudio 362 | Tru S44 amp| TRU SSLD6 LD | 12L7| Alpine M1005| Clifford pager alarm|H-tech|Illumina|CM FSTB| smoked sidemarks(F/B) | Exedy SI |G35c rims | Smoked 2k2 Red tails | Pop charger w/ Asmoil EaA filter| SS clutch line | TSUDO Catback | Stillen body kit
meccanoble is offline   Reply With Quote
Old 09-10-2002, 09:17 PM   #12
Send a message via AIM to ShortT
Damn... I can't wait to get this damn knock sensor replaced and finally see what my car does stock. I'm hoping for low 15's, but damn, 14's would be sweet as hell.
ShortT is offline   Reply With Quote
Old 09-11-2002, 10:17 AM   #13
All Black Max
My car reacted better by shifting earlier then redline. You just have to make sure that you shift BEFORE the traps start (the last 66 feet of track). When the car runs slow cause its hot, I'll push 3rd to redline cause it doesn't have the power to allow me to shift into 4th early enough.
As for launching, I do use a 2700 launch, but not a clutch dump, rather a clutch slip not allowing the rpms to drop below 2200 rpm.
Doug D
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
